Replaced my sway bar bushings.
Used Infinity Q56 Bushings. Way better design that does not allow swaybar to contact the frame. They were like $6 each.
Unbolt sway bar 17mm. Takes a breaker bar. Pull away from frame. Remove bushing and brackets. Put new bushings on bar and press the bracket over them. Torque the 4 bolts to 94 ft lbs. The bushings come pre greased.
Nissan part # 54613-ZV50A
Nissan vs Infinity
[Image: IMAG0072.jpg]
Installed, notice how the wrap around? Nice design.
[Image: IMAG0074.jpg]
Was there a noise produced or something that caused you to notice this? Or did you just notice the need while you were under there changing the oil or something?
[Image: gallery_2_47_63369.jpg]
[Image: 196426.png]
[Image: LIVESTRONG_logo_small.png] - 2 Time Cancer Survivor
How's the feel on those new bushings - are they rubber or polyurethane?
look to be poly...(mine are still in the bag on my work bench..lol) they are made by Timken.
[Image: outrail1-1-1.jpg]
The 2nd Amendment... Washington didn't use his right to free speech to defeat the British, He shot them.
Happiness Is Beating Bama in Anything, Anytime, Anywhere
[Image: 83348.png]
04' Deep Water LE 4x4 CC Off-Road Big Tow, 09' PRO 4X Coilovers & Rear shocks, PRG Mini Kit 2" Front 1" Rear, PRG Adj. Swaybar endlinks, QX56 Swaybar Bushings, PRG Shackles, PRG Off Road Traction Bars, 35" Pro Comp Xtreme A/T's on Graphite OEM 18's, (2012) Pro 4x rear End, Austin E-Lock Mod, Mag Hytec Diff cover, Superchips Cortex, Blue Activetuning Grounding Kit, 6000K HID Lows, Silver Star High & Turns, 3000k DDM HID Fogs, Flowmaster 40, VOLANT GEN III CAI, Throttle Body Screen Mod, Custom Painted Relentless RPM Catch Can, UpRev 2 Deg. Timing Advance, Kenwood DNX514 HU, Sony Explode 4ch Amp, Cadence 6.5" Components, (2) 10" Subs, Vshortt Built Custom Box, Clarion APX-1300 400 watt Amp, Black Billet 9" Antenna, Billet Grill , (3) 8" Procomp 130 watt Off-Road Lights, (2) 55 watt Back-up Lights, Custom Painted Engine Cover V with matching CAI lid.
SEMPER FI
WAR EAGLE
Our trucks will almost be twins once I get that finned cover on there you gave me!
I haven't had any problems with mine but I'll take a closer look and see if this is needed.
Great to know another upgrade is avilable that doesn't cost too much either!
[quote name='BLWedge09' timestamp='1326253426' post='162123']
Just noticed the crappy fit and knew the Infinity option was out there. For $10 why not
[quote name='jdmartin' timestamp='1326291575' post='162126']
I had aftermarket polyurethane bushings on there but they were the same crappy design. These are rubber like oem. Cant tell a difference in ride/feel...
